-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   How to flatten paint chip paint blob (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/891630-how-flatten-paint-chip-paint-blob.html)
ganun 11-18-2015 12:18 PM
Any tips other than being really careful how much paint to apply?
turbo owner 11-19-2015 08:26 PM
Make sure it's thinned enough to flow, use an artist brush to apply and use multiple coats to build it up.
Ferraripete 11-19-2015 11:45 PM
carefully wet sand w/ 1200-1500 grit and buff...go easy!!!
diy83sc 11-22-2015 07:04 PM
^^^ go easy... you can use dish soap as a lubricant to create a surface to float 1200-1500 grit wet-sand paper. I block in onto a paint mixing stick cut down to two inches. The soap helps keep the paper off the paint surface around the paint blob.
To apply touch-up paint, use a toothpick and have patience to only apply as much as the chip will "take". A small amount of paint at the end of the toothpick is enough. Touch the exposed metal and you will see the paint get pulled off the toothpick - capilary action? Wait for it to dry, repeat until you build the paint just above the un-chipped surface. Sand as above.
cary 11-27-2015 06:27 PM
Carefully cut the top off with one of these if you have a big blob. Then wet sand.
Save on Tool Aid 89780 at ToolTopia.com
