Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Door shims
Hi. I would like to move the doors on my 70 targa back towards the rear quarter panel for a more even gap. The door already hangs even to the fender and rocker, just needs moved back. The gap is wider at the top of the door to the rear quarter panel however, I believe this is correct, although I don't know why? I don't want to open a can of worms so looking for the easiest way to do this on my own. Take off door with hinges left on the door, shim, re-attach door?
Cheers
Old 03-26-2016, 02:45 PM
78-911SC's Avatar
Ryan can you post a couple pics so we can see what your dealing with? You are correct the margins at the top are wider.
PJ
78 911sc Targa
70 911T
Old 03-26-2016, 03:57 PM
Emo993's Avatar
Ryan, I had the same problem on my 914. I traced the hinge and cut some shims out of thin sheet metal. After a trial fit, then primed and painted. Worked great. If your interested, I have a master template I could take a picture of and post. Best, Mark
Old 04-02-2016, 09:11 AM
Emo993's Avatar
Ryan, you do not have to take door off. Just loosen one hinge, shim, tighten and go to the next.
I would still mark hinge position with a fine magic marker if things shift.
Old 04-02-2016, 09:13 AM
Hi Mark. Kind of you to offer the template thanks, I would be very grateful...
Old 04-03-2016, 07:21 AM
Emo993's Avatar
Hi Ryan, metal was .028 inch worked for me, could be more or less. Easy to cut and drill. Test fit, prime and paint. Best, Mark
Old 04-03-2016, 04:22 PM
Emo993's Avatar
Images not loading.....what the heck.... will try in a hour....
Old 04-03-2016, 04:35 PM
78-911SC's Avatar
Rayan there has been problems with the server for the last two days. Hoping that they get it fixed tomorrow. PITA can't live without pics. Ha
PJ
78 911sc Targa
70 911T
Old 04-03-2016, 04:59 PM
No worries guys, no rush, just when you have a spare moment. Cheers...
Old 04-04-2016, 02:14 AM
Emo993's Avatar
Lets try again. Best, Mark
Old 04-04-2016, 04:31 AM
awaesome support thank you I'll post how it goes...
Old 04-05-2016, 02:23 AM
