-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   remove undercoating around head light buckets? (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/924605-remove-undercoating-around-head-light-buckets.html)
dre 08-07-2016 11:51 AM
Hi Guys,
I had my fenders dipped with the hope that everything would be perfectly ready to go but alas, there is quite a bit of the ruber undercoating peeling or stuck around the headlight buckets. I cant quite get a wire brush in here to get it all gone so i can start fresh - how do you get rid of it?
I'm seeing these options
-send it back to the dip tank and hope all of it comes loose.
-discover some horrific chemical that can get it off and not kill me.
-remove the headlight buckets by drilling the welds giving me total access to clean, then welding them back on.
Any tips greatly appreciated.
Cook&Dunning 08-09-2016 07:08 AM
I think you are right to be worried about the residue in there - If the original company can't make it right, how about getting them blasted with something?
strikee 08-11-2016 09:17 PM
Drilling out the welds for the headlamp buckets removes quite a bit of metal. There are quite a few of them all the way round the headlamp. I did mine as there was rust in the usual spots and I wanted it gone gone gone. I replaced with aftermarket buckets. Its is very nice to be able to remove the buckets without taking off the fender.
Its not for the faint-heated or for the concors champion.
dre 08-12-2016 08:37 PM
Yup. I defo can't leave it in there. Another thought I had was to make some plastic buckets that could be removable. Not sure if its weight bearing tho.
Dpmulvan 08-26-2016 05:47 AM
Same issue here, I was going to try and blast them.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
