Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
What do I do with this?
I've got a tiny rust spot in the in the cavity in the cowl, where the wiper stem comes out. Is there a good way to get rid of that?
Thanks, Ken
Old 09-26-2016, 01:25 PM
dkbautosports.com
962porsche's Avatar
drop the wiper post down spot sand blast to get clean metal .
you may have to skin the deep pits with a light weight body filler ?
going wet on wet spray one coat of epoxy prime let it flash off then spray a few coats of a filler primer . prep the cowl for paint and then paint you can do a blend up the A-pillars .
Old 09-26-2016, 06:01 PM
Thanks very much 962. I was hoping for a less extensive fix, but I guess we do it right.
Ken
Old 09-27-2016, 01:14 PM
dkbautosports.com
962porsche's Avatar
i would just do it once and do it right it will cost less in the long run .
Old 09-27-2016, 02:47 PM
Cairo94507's Avatar
962Porsche nailed it of course. Do it once, do it right, and never have to touch it again.
'71 914-6 #0372
'17 Macan GTS
Old 09-28-2016, 05:56 AM
