-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   Primer on top of SKS Stonegaurd (water based) (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/945396-primer-top-sks-stonegaurd-water-based.html)
Jonny042 02-19-2017 05:49 AM
Originally Posted by 962porsche (Post 9478697)
JON it takes two .
i tend to just say it as i feel i'm willing to help any one with there projects .
ok so your looking to paint the underside of your car as you know i feel this is one of the biggest mistakes for a number of reasons . the biggest is no matter how or what you do over time down the road you will have the painted finish sandblast to hell .
i have had a few customers ask us to do this and this so far is the best way we have found .
we are going to get right back to the tinted chip guard but you would tint it to closely match the color of the paint color your looking to use . by doing this when the finish does get scratched , chipped and sand blasted you would not see a big difference in the colors from the top coat to the chip guard .
then you would also want to pick a sealer you can also tint to match the top coat color .
when it comes to the top coating you want to use a flex additive as you would use for rubber bumpers . this will add to the impact protection . it's not a cure all never to get damage on the finish but it's a big help .
as we all know the undercarriage takes the biggest beating from sandblasting of road debris .
prep becomes very important when your looking to paint the undercarriage .
spray your stone/chip guard then let it dry . i wouldn't try wet on wet from stone guard to top coats .
once the chip guard is dry sand it with a red pad . an easy way to sand some thing the size of the chassis is to use a DA sander with a hook and loop pad on it .
the red pad with stick to the hook and loop pad because the hooks grad the red pad .
this will get into the nooks of the chip guards texture and not sand the tops of the texture as sand paper will .
with an old pair of scissors you can cut the red pads round to match the DA backing pad .
once you sand every bit of the area blow the area off and clean with a prepaint cleaner .
from this point you can go wet on wet .
as i'm sure you can guess i think it's a very big mistake to paint the under side of the car like this unless you are only going to show the car and trailer it .
this is not to say i don't think it should ever be done i finished a deuce coupe not long ago and i painted the underside of it the same pearl color as the top side . the big difference is the owner is not really going to drive this car . we did all the suspension in chrome and the frame is a gloss black . as we can guess he is not going to drive this car . it's nothing more then a trailer queen ( now how sad is that ? )
porsche's are made to be driven take our loved 86 carrera's don't know about you all but i like that car should it not be driven ?
OMG NO !!!!! even my car with low miles and in very good shape it's meant to be driven and get driven .
it is such a drivers car ! think about its a exotic car you can take to work with great every day road manners and yet take the same car to the track and whoop up on bigger cars .
i have seen more times then i can remember people painting the undersides of there car or spraying rubberized undercoating on them .
any one ever trying to clean it off will tell you the hell job it is many times i have found it easier to fix it we would just end up stripping the chip/stone guard right off the car and just replace it (the chip guard ) .
when we do replace it we use the white chip guard and tint it to match the old 3M product that was used .
i maybe should have stated this from the start ????
you would have a better understanding of what i'm trying to get across and why i feel it's a very bad idea .
Thanks, that really does clarify - I appreciate the lengthy response! I have lots to think about. I'm seriously thinking about switching plans, and going with black for the wheelwells and floor pan now. Black SKS, black sealer, black semi-gloss paint? I'll have to check the RM tech manual I think there's a whole section on painting flexible parts which might be a good reference.
I tried the red pad on the DA - as luck would have it I just replenished my supply of red pads, so I tried this on a 3" 3M DA I have and wow it really works like a charm. A new trick up my sleeve, just goes to show you can always learn something new!!
http://forums.pelicanparts.com/uploa...1487510994.jpg
So like I said, I have some thinking to do - I have had in my head that I would go body color (white) in the wheelwells and the pan, I've probably been brainwashed by pictures in the forum of all the "nice" builds with beautiful clean undersides done in body color. So I am probably going to spend the day staring at it and trying to decide what to do - forge ahead and seal/paint the sks white, or go black (but stick with the original plan in the trunk and engine compartment.
Here is a pic of the car during final test fit/assembly, (minus the black sks in the wheelwells).
http://forums.pelicanparts.com/uploa...1487511552.jpg
It's back apart in pieces now (showing the areas I applied SKS):
http://forums.pelicanparts.com/uploa...1487512079.jpg
kevin930t 03-29-2017 01:37 PM
Looks fantastic.The sks stoneguard is paintable,i would go over the sks with scotchbrite before paint..
Sent from my SM-N910T using Tapatalk
