Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Puma's Avatar
Best die grinder bit?
I want to grind sheet metal on the car to a line for rust repair. Seems like a die grinder bit would work well followed by a mini belt sander for ideal welding.
I've been looking for a good die grinder bit and all I see are sets of ten bits for $15. I have a hard time believing that such an inexpensive set would do a good job and last. Can anyone recommend the ideal shape and brand for what I'm trying to accomplish?
Thanks!
2001 986 S
Old 02-02-2017, 04:59 PM
kgieg's Avatar
use a cutoff wheel or a air nibbler. clean up with a small 1.5" sanding disc. The die grinder may rip the metal.
Old 02-03-2017, 04:17 PM
In my experience, die grinder used on steel last about 30 seconds... Even 10$ ones...
And, no way to sharpen. Waste of money.
On aluminum, they work great.
Old 02-05-2017, 03:53 PM
Puma's Avatar
Thanks guys. I found a much better solution to this problem and am completely happy with the results.
2001 986 S
Old 02-06-2017, 10:58 AM
Puma, I'm trying to solve the same problem-do you mind sharing your solution?
Thanks.
dho
Old 02-08-2017, 06:29 PM
I use flap disks, cheap many different grits and fast.
Old 02-12-2017, 05:47 AM
Puma's Avatar
Thanks.
dho
The biggest reason things weren't working for me is that I tried cheap cut off wheels. I stumbled upon 3M's website and read about the cubitron line and got some from my jobber. The difference is astounding. So now I'm cutting close to the line with the 3M 1mm cutoff wheel and sanding to the line with a 36 grit mini belt sander. The cheap wheel was fighting the metal and making things very inaccurate.
The mini belt sander also works amazingly well for removing spot welds. I'm no longer destroying the underlying panels to remove them. I also use the 3M Cubitron belts.
There may be better methods, I'm no pro, but this is working for me. I'm not affiliated with 3M or anything. Hope this helps.
2001 986 S
Old 02-12-2017, 06:15 AM
Good suggestions. Puma, your experience with the cheap wheels describes the same issue I'm having. Thanks for the input.
dho
Old 02-13-2017, 08:09 AM
