Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
175K911's Avatar
Panel flanger recommendation
Need recommendation for a good panel flanger that can deal with 911 sheet metal. I picked up a vice grip style from Eastwood and it barely makes a dent in the sheet metal let alone flange it. Totally worthless. Need something that works.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 03-26-2017, 06:04 AM
I have 2 hole punch and flange tool combo. Had them for years. Couldn't tell you the manufacturer. Willing to sell one to you for $75. plus shipping
Old 03-26-2017, 02:00 PM
175K911's Avatar
Thanks for the input. How well does is flange 911 sheet metal?
Ed
Old 03-27-2017, 07:11 AM
I have one of these, works great!!
Astro 608ST ONYX Straight Type Punch/Flange Tool https://www.amazon.com/dp/B007QV7WW0/ref=cm_sw_r_cp_api_s1Y2ybCGSEQNN
Old 03-28-2017, 08:44 PM
dkbautosports.com
962porsche's Avatar
i have a few flange tools . but over lapping your panels is not the best idea at all . but welding them is best .
Old 03-29-2017, 07:17 AM
175K911's Avatar
Fiberglassover sheet metal. I had to cut the roof and sunroof out to fully weld the cage. So laying in a 'glass roof panel, I left about 3" of sheet metal around the edges so I could flange and bond the 'glass on.
Ed
Old 04-01-2017, 04:50 AM
The flange tool only crimps about a 1/2" flange with a 1/16 dropped. This would not be suffice to glue the fiberglass section in place. I would fit the fiberglass roof panel to insure the piece fits flush with the existing roof. if it does,grind to bare metal with a 24 grit grinding disc, rough up the underside of the fiberglass roof and use SEM panel bonding adhesive to adhere to the car. use c-clamp vise grips and wooden paint sticks to hold in place. Once cured you will need to use a fiberglass filler to smooth the seams out. good luck, Bob
Old 04-04-2017, 07:48 AM
The Mighty Pieholio
Bob Kontak's Avatar
I have the ST605 ONYX. Probably the earlier version to the one in the link.
I just formed the step on the mangled front spoiler panel off my 81SC using 130 psi no problem.
Metal is 0.047" thick.
Just saying what the tool did. Not saying this is what you should with use with fiberglass, because I don't know.
As noted by Cabrio911 1/2" throat depth by 1/16th offset.
1981 911SC Targa
Old 04-04-2017, 03:51 PM
