Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Mold for PORSCHE letters on enginelid
Is there some sort of mold available to position these letters?
Edit: picture keeps disappearing :-( Used one randomly from Pelican.
Old 03-09-2017, 11:40 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
I'll tell you what I did. I had a spare lid with the holes. I coated the lower area of the lid with a mold release and then laid two layers of saturated fiberglass cloth over the lower part of the lid. Once the 'glass cured I carefully trimmed around the sides and the bottom of the lid. Then from the underside using the correct size drill bit I drilled the holes thru the 'glass. I then carefully removed the template. Now when I need to drill holes for the script I tape the template on the lid needing the holes and drill accordingly.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 04-12-2017, 07:56 PM
