Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 2.75 average.
seafeye's Avatar
Here is the 356
What me speed?
Old 09-22-2018, 09:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
I just finished going through the build. Absolutely beautiful and quality work.
Old 09-22-2018, 05:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
seafeye's Avatar
Been working here and there on the car. After moving into my new house Iíve been busy with other chores. Plus itís still hot in there. I get tired of sweat dripping down my face and mosquitoes having their way with me. So I got some old 100% deet. That may give me brain cancer but at least I wonít be taken alive.
Got the passenger door window frame in. Still need to hook up the 911R strap. Although the windows I got wonít be going up and down.
I could use some advice for the rear quarter windows. They donít curve like the body of the car. Supposedly they are just glued. So has anyone done this that can remember how? At the leading edge of the window where it butts up against the door, where does the glue go? Should I just make an aluminum bracket and pop rivet it in?
Google isnít being much help. Anyway here is some eye candy.
What me speed?
Old 10-02-2018, 04:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
scootermcrad's Avatar
Looks great!!
http://scootermcrad.blogspot.com/
Old 10-03-2018, 09:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
did you install your rear quarters? method used? i've got these rear quarter windows as well and have not gotten around to installing.
If you say you are going to do something: do it.
If you give your word: keep it.
Old 10-10-2018, 07:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
seafeye's Avatar
Iíve been working on the windows. Not much success yet. I did make some brackets with 1 pop rivet to secure in the factory hinge area. I tried to glue in the drivers window. But the glue didnít get under the window fully. So it looked like crap. So I thought Iíd try a different approach. I put a bead of sealant on the window ledge. Then once I install the window Iíll fill the gaps and it should look complete.
My first go didnít go as planned. I got the sealant all over the window. Then it pulled from the car and so the Orange showed through.
Iím thinking that this approach will work. But I will need better sealant. Will look into some 3m stuff that cures faster. Till then...
I did get to finally bleed the brakes. I ordered a pair of rear calipers from our host as I wasnít happy with the condition of my old ones. The pedal is firm. 1 small step forward.
What me speed?
Old 10-10-2018, 06:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
seafeye's Avatar
Nice to get the brakes done.
Next is to figure out how to get the oil tank to stop moving out of place.
What me speed?
Old 10-10-2018, 06:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
seafeye's Avatar
The wiring for the oil tank was a bit short. So I made an extension today. And put a connector on about 1/2 way. Saves me having to pull the oil tank if I need to get at the wires. Also made sure the rubber on the strap was secure so when the tank gets tigened down it doesnít rotate forward.
Then I got bored of that so I decided to install the front bumper. The seal was a bit difficult to get into the groove on the latch panel. But perseverance paid off. I used a little 3m sealant to help secure the seal. I think it fits pretty good. Iíll be able to get the bumper lined up nicely. Then the hardest part of the day. Drilling the hood for the hood straps. My phone just had to ring about 5 times during the process. I hope they are centered. My crooked view they look fine.
What me speed?
Old 10-11-2018, 03:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
seafeye's Avatar
Life gets in the way of projects from time to time. The weather is perfect for driving but Iím still tinkering. I have been putting off installing the MSD ignition for a while. I think because Iím worried the non Porsche stuff will ruin the engine bay. I think it distracts from the simplicity of the car but after I installed it today, I was happy with the result. Still might be a bit cramped in there but having a good reliable twin plug system should have positive results. Only question I couldnít find an answer to is...
I have two grey wires, or from each ignition module. Do I use both to send the signal to my tack? Or just 1? Logic says just 1 is needed. I can always swap them over to check the rpmís. Anyway. I didnít follow my logic and going to try it with both. Whatís the worst that can happen? Not sure I like the silver nuts showing on the inside of the car. But I think having the boxes up under the shelf is a good 1/2 hidden spot.
What me speed?
Old 10-17-2018, 05:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
Rodney Nelson's Avatar
Hi Seafeye,
Looking good. Sorry I don't have an answer to the tach let us know if you find out the solution. It sucks how you put so much work into preparing the body of your car and then you have to drill holes into to attach components!
Keep the updates coming!
Rodney
Rodney Nelson
Certified Porschephile
'82 SC (White) sold
'86 951 (Guards) Burned to Death
'71 911T (Orange) Sold
'72 911E (White) Sold
'86 951 (Black) Sold
'79 SC (White) Sold
'71 911 T (Green) Sold
Old 10-17-2018, 06:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
lateapex911's Avatar
One should do the trick. THats what the tach is driven off in stock form, correct?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 10-22-2018, 07:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
I'm having a hard time wrapping my head around those quarter windows; haven't seen anything like them in the flesh so cannot visualize how they are really meant to fit. My Alfa GTV has opening rear quarter windows; you might find their hinge system interesting. That orange just leaps off the screen. John
Old 10-24-2018, 01:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
seafeye's Avatar
I’ll try post some pictures of the quarter windows when I finally get around to installing them. The rear lights are posing a problem because the mounting holes don’t really line up. More on that later.
I’ve been busy working on the electrical system. Gauges. Wiper motor and blower motor. Some old parts are cracked. Typical of a car in a hot climate I guess.
The new dash I installed looks like a million bucks. Best $1000 I ever spend. Aside from that night in Vegas of course. I wasn’t t going to do the trim down the center of the dash. Or the glovebox door etc... but the hazard switch wouldn’t fit. It’s sized to fit in the trim panel.
So to keep the car unique. I decided to use black leather for the trim. Will match the leather seats.
I have the proper material if I decide to go to a more factory look. I’d sure like to get a badge for the glovebox that says “911R” if someone has the talent to make one.
Currently I’m held up with the light switch. Mine is toast but thankfully a fellow pelican is sending me one from Florida. Well here is the progress. Doesn’t look like much but quite a bit of work. Next time I’m taking better pictures for reassembly.
I need to clean up this mess.
What me speed?
Old 11-08-2018, 04:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
The Dash does look awesome, where did you source it?
Also, is the dash emblem smaller than the one on the decklid? I just found a 911R emblem on ebay.
Rodney Nelson
'82 SC (White) sold
'79 SC (White) Sold
Old 11-09-2018, 06:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
seafeye's Avatar
Been busy working on the car. Not so busy posting updates. Here are a few shots.
Headlights and horns installed. The wiring harness finally completed. Although my wipers only work on speed 3. And intermittent. Think the diagram might be off. Iíll gave to fiddle with the order of the wires.
Tried to post a video of the engine running but I guess pelican doesnít allow direct uploads. Iíll try get it up on YouTube.
There isnít a cold start valve so it is a bit fussy when first started. Pops and spits. The MSD and JB Racing distributor work well together. Only problems so far was no tach and no oil temp.
I fixed the tach with the product from ratech. Just connected the grey MSD tach wire to the ratech unit then to my purple/black tach wire.
Temp gauge is broken Iím assuming. Pretty hard for a sender to go bad I think.
My oil cap handle broke and itís been a killer to find a replacement. But a 1950ís beetle cap seemed to do the job. Just need to get the handle welded on.
Lastly had a gas leak. One of the plugs on the tank was dripping. Making for a stinky garage. Just a pipe wrench tightened that up. Next up..... rear lights.
What me speed?
Old 12-01-2018, 11:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
WOW !!
Great job. love thew color
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 12-04-2018, 02:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
seafeye's Avatar
Sure looks better with the rear bumper attached.
What me speed?
Old 12-04-2018, 03:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Man I wish you were closer to S Cal so you could get this in Luft 6, I'd love to see it in person. Sano!
Old 12-11-2018, 10:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
seafeye's Avatar
I said I wasnít going to put in carpet but then I change my mind. I bought a set of RS charcoal lightweight carpets that Iíll put over top of the black interior. One of the reasons was that the black was showing every bit of dust I could find its way inside the car and also I didnít think it would hold up well too scratches from wear and tear. Anyways the carpets are installed I think they look fantastic and I found a pair of real authentic Recaro racing seats from the 60s here on pelican. They cost a lot more than I wanted to spend on pair of seats but a couple years down the road ill have forgotten the cost of them. The seats were refinished in San Diego and the only difference is that their leather instead of vinyl. Iím still fidgeting trying to figure out what Iím gonna do for seatbelts I have stock ones but the mounting points donít seem right. Itís great being able to go out into the garage and start the car it starts up right away Iím just need a couple more things and then Iíll be able to take it for a drive. Windshield is the big thing missing. And I still need to put in the 911 R rear corner windows.
The rear wheel studs were too long for when the car had that wider wheels on so I pressed out all the old studs and installed shorter ones still might be a bit long but it something I can live with.
What me speed?
Old 12-29-2018, 02:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
seafeye's Avatar
Also had a problem with the oil line coming from the engine cooler. My car is a 1971 and Iím trying to modify using the 1972 oil tank. Well the 1971 engine oil cooler has a screw one oil line where as the 1972 was a press on. I made an adapter but it ended up pushing the oil line too close to the rear tire I had to take it off and shorten the oil line. I think itís at a comfortable distance away from the wheel now. And here are the couple pictures of the wheel studs canít really tell the difference but the new ones are definitely shorter.
What me speed?
Old 12-29-2018, 02:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
