Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Bare metal for grounds, after paint ?
In order to have good contact for the electric ground. After a complete paint, how do you scrape the new paint in the areas where the grounds are located ?
Specially where there is a bolt and an eyelet terminal connector?
Old 11-14-2017, 11:39 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Good question. I know these types of washers are desirable in all ground applications.
1981 911SC Targa
Old 11-14-2017, 12:41 PM
Bob, thanks for your answer. I am planning to use those kind of washers, but want to have better contact and was thinking on scraping the paint but do not know how to do it without making a mess with the new paint.
Good grounds are needed to avoid hidden electrical problems.
Old 11-14-2017, 01:34 PM
Pauld_94S2's Avatar
Place a small diameter metal or PVC tube/pipe against the metal and stick a sand blaster nozzle inside.
Wrap a towel around the whole thing to contain the abrasive.
Pull the trigger for just a second or two (experiment on old paint, assuming your sand blaster is good) and remove the tube/pipe. Depending on diameter of the tube/pipe, you should have a real nice bare metal area to use for a ground. If you have a bolt already there put a couple of nuts, thick tape, or old rubber hose line to protect the bolt threads.
Enjoy!
Old 11-14-2017, 03:44 PM
