Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Fuel filler door fitment issues
Anyone have any hints on how to get my fuel filler door gaps correct. The left side of the photo is where the hinge is, and that's also the side with the large gap. I see no way to move it in that direction to even out the gaps. The long sides I can even out as there is enough adjustment range, but the left/right alignment has me stuck.
Bill
Old 01-09-2018, 08:53 PM
dkbautosports.com
962porsche's Avatar
the hole fuel door is misaligned you will have 3 bolts holding the door to the fender . two upper bolts and one lower one .
under the lower single bolt between the hinge and the fender put a shim washer . this should take the top part of the hinge and move the door forward .
Old 01-18-2018, 06:18 AM
Thanks! I was hoping it would be that easy. Will give it a try when I have a few minutes.
Bill
Old 01-27-2018, 06:50 AM
