-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   painting tail of 89 Carrera (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/985171-painting-tail-89-carrera.html)
cmcfaul 01-23-2018 08:26 AM
Hello all,
I just want to respray the black portions of the whale tail. Tape off the red and rattle can the black with a matt black.
How do i tape off the corners getting a nice clean round corner?
Many Thanks
Chris
89 Carerra
http://forums.pelicanparts.com/uploa...1516724763.jpg
962porsche 01-23-2018 07:16 PM
use a fine line masking tape i personally like the green fine line tape . they have blue but it's to stretchy for my liking . the green in 1/16" will work .
mask it off then scuff it with a red pad or gray scuff pad . unmask it then remask it .
if you get lazy and don't remask it the edge will look fuzzy .
i would also opt for a two part paint not a single part spray can . a two part or paint with a hardener will last many years a single part you will be repaint it in a year or two .
if you go to eastwood look up 2k aerosol blacks .
cmcfaul 01-24-2018 07:52 AM
Thanks for the detail. Is it remasked because the edges get fuzzy during the scuffing process?
Next stop is eastwood. Why not do it right.
Chris
962porsche 01-24-2018 01:30 PM
yes your going to need to sand right up to the masking tapes edge so it will screw up the tape some and the tape will get some sanding crap stuck to it .
cmcfaul 01-25-2018 08:57 AM
I ordered the Eastwood 2k aerosol (Ratrod matt black). I talked to a person there and that was what they recommended. Going to home depot for the tape and scuff pad. Now need a warm weekend to get it done.
Chris.
73pcar 01-25-2018 09:43 AM
Home Depot won't likely have the proper scuff pads or the referenced 'fine line' tape...both are usually only found at an auto parts store, and even then, only likely at one that also sells autobody supplies to include a paint line.
962porsche 01-25-2018 12:53 PM
home depot will have the scuff pads but not the fine line that you can order from eastwood too i'm guessing .
Bob Kontak 01-25-2018 02:19 PM
Find a paint jobber or like 73pcar says a parts store that is heavy into paint mixing.
I like the rattle can 39143 SEM Trim Black. It will work fine.
However, when I painted my fuchs, I used a Glasurit 22 line paint with a flattener that came out spectacular.
You are talking $20 for SEM but a boat load for Glasso. Not so much the money, just fiddling with the flattener to get the right hue. Well, maybe the money too. You have to buy the hardener and it's by the quart. Ouch.
I have the formula buried in these forums somewhere if you are a glutton for punishment.
Your paint was rubbed thin by a buffer, guessing.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
