How to remove glass from vent window frame
73 911Targa. I've got the window trim out for rechroming and can't get the front swing out vent window glass out of the three sided window trim. Either has a small seal, tape or adhesive holding it. i have tried a heat gun, some WD-40..... Need help. Thanks, Mark
Mark, Have you found a satisfactory method with your glass removal? I will be trying the same with my 73 targa,in the future. Rob
Take a look at the link below to an earlier thread where this is discussed. There are a lot of guides if you google 'remove glass from vent window frame porsche'
http://forums.pelicanparts.com/porsche-911-technical-forum/101573-vent-window-glass-removal.html |
| All times are GMT -8. The time now is 06:00 AM. |
