Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Removing paint from Valve Covers
Previous owner must have had lot's of extra brake caliper paint!!
Painted cam shaft covers and chain covers with brake caliper paint.
Any secrets to removing the paint?
Should I spray with VHT clear when I have the parts clean?
Old 05-24-2018, 06:41 PM
Speedster, what have you tried so far? I'd think you should use aircarft stripper, a plastic scraper, scotchbrite pads and/or stainless steel wall and all sensible safety precautions. Once you've stripped them to perfection, I personally wouldn't use rattle can clear (not very durable); I left mine natural and they're fine three years later. If you do want them coated, maybe talk with Shaun at Tru-6 (frequent PP contributor) who is a serious coatings guru. Best of luck, John in CT
Old 05-26-2018, 04:42 PM
Make sure you clean parts well after aircraft stripper. Rattle can paint is a waste of money as far as I'm concerned. Either use a 2 part clear, or have them powder coated or better yet ceracoated.
Old 05-29-2018, 05:39 AM
I haven't tackeled this project yet so thanks for the suggestion on the stripper. I forgot to mention - engine shroud and fan were also painted so it's a rather major project and I want to do itonce and do it right.
Old 05-30-2018, 10:43 AM
onboost's Avatar
Use the paint stripper on the fan and valve covers, after you've washed/rinsed them good, clean them again with acetone.
Regarding the shroud, if you're not used to dealing with the stripper, then simply sand it down with 180 and go back over w/220. You don't have to strip this bare you just want to scuff it down and feather any rough edges that are in the line of sight when installed.. prime it and shoot it.
Its fiberglass and if you leave the stripper on for too long or don't clean it well you wont be happy.
RGruppe #180
Old 06-07-2018, 08:06 AM
Discseven's Avatar
Speed... are parts on or off car?
Karl ~~~
Current: '80 Silver Targa w /'85 3.2
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver/Black/Anthracite 930s.
Old 06-26-2018, 04:34 PM
currently on, I will take them off to clean.
So many projects are poping up around the house this year preventing me from working on my cars.
Old 06-26-2018, 08:11 PM
The Mighty Pieholio
Bob Kontak's Avatar
Go to Lowes or Home Depot.
Get Jasco epoxy paint remover. The $29 per gallon stuff, but you can buy by the quart.
1981 911SC Targa
Old 06-29-2018, 04:40 PM
I can suggest you for fan and valve covers. There you can use paint strippers on them and once you've rinsed them good, clean them again with acetone.
Old 08-02-2018, 10:05 PM
want to thank everyone for their guidance - The epoxy stripper has worked great.
The paint on the calipers was so thick, It took 3-4 coats of stripper and about 2 hours wait time to start devolving the paint.
Old 04-05-2019, 04:17 PM
