Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
KYUKYU3
samurai_k's Avatar
Respraying a bumper cover help
Hey all,
I am wondering you bumper repair/paint experts can help me.
I picked up a beat up 993 plastic bumper cover and splitters for nothing and want to get it resprayed do a few mods to delete the bumperette cut outs and license plate holes.
The bumper cover and splitters have a terrible respray job where you can clearly see someone tried to spray a section and not the entire bumper so there is overspray in a few places and orange peel where it was resprayed.
I used some 220 and a DA to strip the paint down to the primer so I know have a smoother surface to start with.
Should I continue removing the paint in the crevices or leave it on? There are no adhesion issues with the paint that is there.
Thanks!
Old 05-31-2018, 10:31 AM
Administrator
Dmitry at Pelican Parts's Avatar
Do all the modifications to the bumper first, then get everything to the primer, then repaint.
Old 05-31-2018, 01:37 PM
KYUKYU3
samurai_k's Avatar
Hey guys finished the refurbishment/refinishing of this cover. Ended up deleting the license holes, bumperette cut outs, and the cross bar.
For the license plate holes I used SEM problem plastic repair as my filler/adhesive to fill the holes, drywall fiberglass seam tape as a reinforcement.
For the larger sections I used pieces of plastic cut from a cracked splitter (same plastic as the bumper) and glued it/riveted it into the bumper as a backing. Came out better than expected.
Old 09-08-2018, 10:01 PM
Bill Douglas's Avatar
It looks nice and even. Do you have to use a special primer and paint for over plastic and to cope with the flex and movement that happens with plastic bumpers?
see www.lyallbaybeach.co.nz
Old 09-09-2018, 08:13 PM
KYUKYU3
samurai_k's Avatar
The finishmaster pro recommended I use the SEM products for the job. I brought in the bumper and they said I didn't need a flex agent in the primer since the bumper is semi rigid. So what I did was:
1. Strip the bumper down to the plastic. This was a royal PIA as there was way too many layers of paint.
2. Clean it well. I had a sem plastic prep solvent
3. Do the repairs and mods with the sem plastic repair
4. Block and feather the repair/mods. The sem plastic repair sanded really nice. I had to do a few tight coats of it on some of the transition areas to the surrounding areas to get no lines. I had bought a can of Evercoat polyflex that I was going to glaze with but ended up not having to use it.
5. A coat of sem high build primer. A coat of sem guide coat. Blocked it and found no issues. Topped it with another coat of the primer and blocked it again.
I spent way to many hours, but learned a lot through the experience. I learned to do drywall taping and cabinetry finishing a long time ago so some of those techniques helped me through this learning process.
Old 09-09-2018, 09:38 PM
Are you done painting it? Any pics?
Old 10-09-2018, 10:43 PM
KYUKYU3
samurai_k's Avatar
I am waiting this winter for a respray, so I temporarily vinyl wrapped it with some black spray plasti-dip to hold me over... Here is a pic from rennsport. Mine is the blue one.
Old 10-09-2018, 10:49 PM
