Rear parcel shelf sealant
The shelf is spot welded in with a gray sealant put over the seams what is the recommend replacement product to use???
in my shop we only use SEM's two part seam sealers . i have found nothing better on the market .
Do you use SEM High Build Self Leveling Seam Sealer - 39777
or SEM Heavy Bodied Black Seam Sealer - 40377 Thanks Mark |
we use all sem's products . self leveling is runny only use it on some thing flat . or you have to build a dam out of tape if you want to use it on an angle . you need to pick the seam sealer for the job at hand .
