Go Back   Pelican Parts Technical BBS > 5 - Miscellaneous > Paint & Bodywork Discussion Forum
Rodney Nelson's Avatar
need to purchase reasonably priced MIG welder
Hi Pelicans,
I'm going to be doing some rust repair and I'm on a budget. I need to purchase a MIG welder. What do you guys think about these welders below? Also, will I need gas?
I need to change out the front latch panel, cut out part of the front pan, replace the entire parcel shelf, replace both rear seat sections plus cut out and misc. weld areas, so it is going to get some use.
I would appreciate some well educated suggestions on whether the below units would work and which ones you would suggest. what about gas bottles can I add them and do I need them?
MIG Welder | MIG Welders | MIG Welding – Eastwood MIG 135 Welder
https://www.lowes.com/pd/Lincoln-Electric-120-Volt-MIG-Flux-Cored-Wire-Feed-Welder/999972168
https://www.harborfreight.com/170-amp-dc-240-volt-migflux-cored-welder-61888.html
Thanks for your help,
Rodney
Rodney Nelson
Certified Porschephile
'82 SC (White) sold
'86 951 (Guards) Burned to Death
'71 911T (Orange) Sold
'72 911E (White) Sold
'86 951 (Black) Sold
'79 SC (White) Sold
'71 911 T (Green) Sold
Old 11-02-2017, 07:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
pete3799's Avatar
Of those three choices i'd go with the Eastwood.
You'll definitely want gas.
I've got a Hobart 140 you might want to check those out as well.
Pete
79 911SC RoW
Old 11-02-2017, 08:10 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
lite75's Avatar
I've had one of those Lincoln welders for years, works great with shielding gas.
75 930, 76 930, 83 SC EFI turbo
Old 11-04-2017, 06:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
I've had an Eastwood for about 10 years it's ok welds fine just don't use the crappy wire it comes with and make sure to loosen the tensioner when your done welding. You want to weld with gas co2 argon mix, flux core is messy. Actually for cheap welders I would buy the ahp and tig weld all your panels in. I probably wouldn't have bought the Eastwood it was a gift but it's been a decent welder for occasional use and hasn't let me down yet.
Old 11-05-2017, 05:02 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
as a fabricator myself, I would go with the Eastwood. better to be able to control your wire speed and amps manually .
whatever you do DO NOT go with the harbor freight one. JB weld is better then those. joke but for real.
Jeremy Brooks AKA VWLOOSENUTS
www.vwloosenuts.com
Old 11-07-2017, 08:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Go on craigslist, you can get a MIG welder with tank for a good price.
When buying the welder, don't forget to figure in the cost of a the tank with co2/or argon. Don't get the smallest tank, you can run out of gas pretty quick.
Budget $200-300 for the tank and gas...
Old 11-07-2017, 08:51 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
You get what you pay for on MIG welders. Gas is the ONLY way to go. I have a 30 year old Lincoln that works great. Find a used one on Craig's Lists.. I hear that some of the new MIG welders use a 120 Hz Cycle, which translates into less sputter, smoother and better penetration.... look around for places to fill your tank. I was filling up in the Big City of Columbus OHIO, and it was costing my around $50 to fill my tank......I found a farm equipment parts holeinthewall shop about 3 miles from my house in the country and it only costs me $17 with tax now.... that's the 75% Argon 25% CO2....
Old 11-09-2017, 09:14 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
jeff968's Avatar
I have a used Miller I got on eBay. Works great for 10 years now.
Old 11-09-2017, 01:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
The Mighty Pieholio
Bob Kontak's Avatar
+1
I have a Lincoln 220 MIG welder with gas. Two years now. It was $750 at Home Depot. Comparable Millers were $1,200 plus. Lincoln is great and I am getting better with it.
I don't think you can go wrong with a used Miller. They are better welders than Lincoln.
I know you are on a budget and I can appreciate that. I would rather see you buy a used quality welder with gas.
I believe that a 110 welder can do most anything a 220 welder can do save heavy welding. With cars, it's sheet metal and mufflers pipes. If it's heavy, replace part.
Gas is a must. You don't want Innershield.
1981 911SC Targa
Old 11-14-2017, 02:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Slippery Slope Victim
NY65912's Avatar
My Hobart 140 has served me well. I can do 22ga to 1/4". No matter which one you buy, practice and become familiar with it.
Mike²
1985 M491
Old Today, 07:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
