Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
61 356-B running hot on freeway
This limo runs about a little above mid range on the temp gauge on the street. On the freeway it gets pretty warm about 3/4+ almost 7/8 on the temp gauge. Brakes are not dragging, motor just serviced. What's up with that ???
Old 12-20-2018, 04:59 PM
I had one that did this I wonder if they cleaned the oil cooler in + out fully when they did the motor also make sure it has the later style ( large ) air cooler !
Old 12-21-2018, 07:11 AM
oil might not be getting to cooler …. bypass check piston my be stuck
Old 12-21-2018, 10:04 AM
Is the timing set properly? Is the air cooling path clean?
Old 12-27-2018, 06:50 PM
