Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
356 tire sizing
I'm sure this has been discussed many times and I did do a forum search but nothing came up.. I would like to use a 16 x 5.5 rim on a 59 coupe.. I would like to know what maximum diameter I can use without a rubbing/fitment issue arising ? Has anyone used this set-up ?
Old 11-14-2019, 11:02 AM
Administrator
Dmitry at Pelican Parts's Avatar
Check out the below links, perhaps it'll help you out.
356 tire size
64 Porsche 356C wheels/tires?
356A TIRE SIZES/TYPES
Old 11-14-2019, 12:27 PM
I've not run a 16" wheel, but I've run a 15 x 6" on a 56 coupe. I ran a 205/55 15, so perhaps you can run a 205, but I don't think you'll get a 225/50 underneath there. Even with a 205 I think you might have to shave down the upper rear bump stops (I did) to clear on the inside.
Probably want to check the "outlaw" section on the 356 Registry.
E
http://www.autoforeignservices.com/
57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc.
Old 11-15-2019, 10:47 PM
Google " Porsche 356 tire size "
Several threads on this has been discussed on the 356 Registry.
Here is one thread.
What Tire fits - Porsche356registry.org
Old 11-20-2019, 10:25 PM
the only 16" wheels ever mounted on a 356 were during the pre A years, those were 3.25 wide and were clad with 5.00 width tires (which are skinny). I think with a 16 you may get away with a 195/55 (195 is officially the max you can go on a 5.5" rim).
You may rub the inner wheel well at full turn.
Old 11-26-2019, 10:23 AM
