Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Negative battery terminal clamp hot
Hi Guys,
When cranking over engine (& currently not starting) the negative (ground) battery terminal clamp becomes hot to touch - hot enough to not want to leave my finger in contact.
I have cleaned both battery lead ground and the transmission to body ground - strap is the correct type and in new condition.
Have just had the starter motor out to replace the transmission housing bush. Dismantled and cleaned starter motor. Didn't bench test it as it was working OK before but was spinning slower than I'd like.
Any ideas?
Thanks,
Gary
Kiwi
Reg # 381
1959 356A Conv D
1967 912
1972 911S
Old 04-26-2020, 10:21 PM
Cajundaddy's Avatar
Possible shorted winding in your starter. If you have a meter and can test for full load amps this would tell you if the starter is within spec.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 04-26-2020, 10:43 PM
Thanks Cajundaddy. I’ll follow up on that!
Kiwi
Reg # 381
1959 356A Conv D
1967 912
1972 911S
Old 04-27-2020, 12:20 AM
