912/356 rotors, same?
Are the rear rotors on the disc braked 356's the same as the rear rotors on the early 912's?
The rotors on my 912 have a circular opening in the hub mounting surface (center). The 356 appears to have scallops cut out in-between the stud holes, but otherwise looks the same. Whats the difference? Dave A |
The C/SC rotors and the 912 rotors are interchangable as are the early 911 rotors.
Kelly |
Hello
AFIR the 356/912 rear rotors are the same. The cutouts were needed to clear the oiltube cuming out from the lining protector. The 356 have a swingaxle witch has the outer bering in oil. A failure would oil up the drum so there is a inner catchring with a tube going outside. Roland |
| All times are GMT -8. The time now is 05:27 PM. |
