-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   Valve Adjustment Difficulty (http://forums.pelicanparts.com/porsche-356-technical-forum/1137632-valve-adjustment-difficulty.html)
DavidLeavell 04-03-2023 03:32 PM
Greetings.
I am adjusting the valves on my 1963 Cab for my first time. Cylinder number 3 exhaust valve is pressed tight to the valve stem. I loosened the holding nut and began turning the adjustment screw counter-clockwise and it stopped after several turns without opening a gap to make an adjustment. Intake valve on #3 adjusted OK as well as both valves on cylinder #4.
Suggestions?
Thanks,
David L.
Paul T 04-06-2023 03:22 PM
Originally Posted by DavidLeavell (Post 11963568)
Greetings.
Suggestions?
Thanks,
David L.
are you absolutely sure you are at TDC?
