Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Want to swap a pressure plate?
I have a few I can swap, various years, various models, but need a late (1965 356C or 912) 180MM pressure plate. Let me know.
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 06-25-2004, 03:28 PM
id10t's Avatar
umm... doesn't the c/sc/912 use a 200mm plate?
Old 06-25-2004, 05:15 PM
914Ghost's Avatar
Change the flywheel, get a bigger clutch.
The 180mm stuff is 100% VW.
More or less Designed for 40 Hp.
Bob O
If it aint broke.. ... ... .fix it anyway.
Old 06-27-2004, 08:15 AM
Not mine. I'm putting a 912 engine in my '65 356C. The 912 flywheel wouldn't work so I picked up a 356 flywheel. I have the clutch for it but not the pressure plate...180mm.
Old 06-29-2004, 07:11 PM
914Ghost's Avatar
Doood... okay check it out-
Send your 912 flywheel to Walt @ Competition Engineering - in California. Have them put the 356 ring gear you need (maybe 6 volt?) on the 912 flywheel and use the 912 stuff- it'll go right in. It rocks.
I did that on my 60' S-90 and it was the BEST thing I ever did.
Seriously felt like a 911 clutch.
I need a 912 clutch plate if'n you end up with an extra.
-Bob O
Old 06-29-2004, 08:18 PM
