lost key
While I'm waiting for a lcoksmith and key blank, has anyone ever hot wired thier ignition switch, if so how?
Thanks, Chas. 69/912 63/356 |
I think you'd have to jumper the back of the ignition switch so that it was effectively in the "run" position - sending power to the coil. Then somehow get hte starter to turn over and the solenoid to engage (jump the big thick cable to the spart solenoid connection, or run a wire from b+ on the regulator to the spare terminal on the solenoid, or push start it).
BTW - Tony E. "the key man" who advertises in the Registry magazine should be able to cut you a new key by key-code number for the lock (K-1xx or K-3xx). |
I figured it out, no wonder they put trans locks on them.....
| All times are GMT -8. The time now is 11:52 AM. |
