Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
kzm kzm is offline
912 & 356 engine parts new & used
A friend of mine closed his Porsche shop a few years ago and has a garage full of new and used 912/356 engine parts for sale at very low prices. All are origional German factory parts. You name it he probably has it. Lots of cases, heads, rods, rebuild kits, sheet metal, carbs, etc.
Let me know what you need and I'll get the availability and price ASAP.
Old 09-23-2004, 04:53 PM
New late style oil cooler(s) ; pair of 912 heads; 616/36 case all 3 pieces; 68 912 smog pump set up complete with crank pulley; Early & late engine main bearings any & all sizes ; Exhaust valves ATE 3048 ; ATE Intake valves 3044 ; New valve springs ; C crankshaft - std/passed mag; Solex 40PII steel fuel lines complete; 200mm 356 flywheel; 180mm 356 flywheel; New 180mm F&S pressure plate & disc-356; 356 OE plug wire ends; New push rod tubes; 912 pushrods & complete valve train-rockers & stands; New 15 or 16 camshafts or used with no wear on gear slot; 356 four hole crank pulley; Factory P7 valve spring tool
OK for a shopping list?
Please email off line with response. Let me know what you have, quantity of each & price each. Thanks, George angelina90@knology.net
Old 09-23-2004, 05:15 PM
