Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Aux Air Valve
Hi all and happy new year,
Had some work done on my 82SC recently and after getting home discovered I had a hunting idle when cold. Checking further discovered the WUR was unplugged and getting no power, ditto for the AAV. Plugged the WUR back up but cannot figure out where the aux air valve plugs up to, the plug is attached to the valve but not to the harness. The wire runs from the valve over the top of the engine and is sitting close to the WUR. The wiring info. in Haynes seems to indicate the AAV draws power from the WUR but I cannot locate where?? Any ideas.
Thanks.
Pete
82 911SC
77 R60
Old 01-03-2005, 04:33 AM
