-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   VW motor into 356 B T6? (http://forums.pelicanparts.com/porsche-356-technical-forum/242944-vw-motor-into-356-b-t6.html)
Russ Cochiolo 09-26-2005 01:45 AM
I've inherited my mothers "Honeymoon Special, 3 Generations". It is in need of a motor rebuild. I intend to put a VW motor in until the original motor can be rebuilt. What problems am I going to encounter? Thanks. Russ
id10t 09-26-2005 05:07 AM
Fitting the sheet metal, maybe the clutch setup, maybe generator/regulator voltage
bt1211 10-05-2005 06:48 PM
It should not be that hard. Finding the right clutch, pressure plate and bearing might require some research. Is a T6 6v or 12v? If its a 6 you can use 6volt VW stuff or convert it to VW 12v. None of this is going to be hard to do. Fitting the sheet metal can be accomplished with a cardboard mock-up. Or you can give me a deal on your T6.
Bryan
Waz356 10-05-2005 07:46 PM
Standard T6B would be 6v.
bt1211 10-10-2005 09:27 PM
There is a guy with a 58 for sale on 9/21, the car is sold but it had a VW engine. his handle is BLKIXXI. Ask him what he used.
