Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
75 or 90HP
my dad ownes a porsche 356 B T6 from 1963.
the back of the car has a porsche S badge.
is this a super 90 or not.
the car is bought in cali and shipped to belgium lat year.
we have it from the first owner who bought the car in LA in1963.
we also have a document from porsche usa the claims all motornumbers,gearbox and vinnumber is factory original to the car.
thanks for helping us out with some info abought this engine
Old 12-20-2005, 01:20 AM
is there maybe a super 90 owner here on the forum that has the possibility to post a picture of his engine onhere?
thanks
Old 12-20-2005, 01:31 AM
Waz356's Avatar
Hi bjornvw, for 1962 and 1963 only, Porsche used the 60, S and 90 badges to designate their 356 model range. The S was the 75hp model. You should be able to get more information from the engine and chassis number and also check with the 356 Registry. Hope this helps.
Cheers, Warren
'61 356B Coupe (Kate), '62 356B Cabriolet (Hannah)
'74 VW Kombi (Rex), '84 928S (Louise), '98 996 Cabriolet (Babs)
Old 12-20-2005, 02:46 AM
we already put all the body numbers etc in the registry 356 website.
but you still cant see if its a super 90 or not .
i will ask my dad for all the numbers again a look one more time on there website.
thanks for your tip
Old 12-20-2005, 02:52 AM
id10t's Avatar
Go to www.356a.com and plug in the engine number - its on the generator stand. It will tell you what the engine left the factory as (who knows what a rebuild did) and what cars it would've been used in.
Old 12-20-2005, 04:45 AM
The engine looks like a super 90--Solex carbs and gray fan shroud. I believe the super 90 engines were numbered 80xxx
Old 12-20-2005, 12:35 PM
Waz356's Avatar
If it is as you say, all matching numbers, and nothing has been changed, then as an "S" it is the 75hp model. You would need the cars COA from Porsche to verify how the car was specced new. As a 63 model, if it was a Super 90 then instead of an "S" there would be a "90".
Cheers, Warren
Old 12-20-2005, 01:42 PM
ok am just back from my dads garage and took a look at the engine again.
the motor nr is 704603 so its a 75hp .
so the engine is original to the car.
A lot of people here and on other porsche forums said that the carbs are solex so like the super 90.
If you see the engine then the connection from the carbs and carbs itself look still pretty clean compared to the rest of the engine.
so the only possibility is that they put a set of original Super 90 carbs on 75hp engine from my dads car.
Old 12-21-2005, 02:54 AM
