Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
King Pin info needed:
I found some play in the passenger side suspension and traced it down to a little "slop" in the king pin assembly. After removing everything from the torsion housing outward, I found that there was just a tiny bit of up-and-down movement in the spindle assembly. No side to side, no wiggle at all, the spindle just moved straight up and down.
Are there thin shims that can be installed to reduce the movement/take up the space, or is a complete rebuild needed?
I'm totally new to this, but can pretty much do anything if I need to.
Any help would be terrific!
Thanks,
TC
Old 07-10-2006, 05:36 AM
