-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   wheelbase and track width questions (http://forums.pelicanparts.com/porsche-356-technical-forum/305832-wheelbase-track-width-questions.html)
p-nor 09-22-2006 07:59 PM
were all 356's the same wheelbase/track width and does anyone know exactly what those measurements are?
thanks
paul
id10t 09-25-2006 05:26 AM
Think so. Info may be in Elfrinks, but I don't have mine handy.
drauz 09-25-2006 11:25 AM
356s have a whlbase of 2100mm, a frt track of 1306mm (preAs: 1290) & a rear track of 1272mm (preAs: 1250). growth in whl width accounts for variance. of course, there may be unique exceptions - it's Porsche!
p-nor 09-25-2006 04:47 PM
thanks for the replies guys. i found the info on the carfolio site yesterday. here's the link in case anyone needs any specs.
http://www.carfolio.com/specifications/models/?man=5318&Porsche
paul
drauz 09-26-2006 08:17 AM
I looked over a number of their 356 model specs at Carfolio. While it may be data, it appears to be "user sourced", so I wouldn't rely on everything there as THE data. For definitive info, I recommend the factory owner's manuals or reliable sources that directly tap factory data (ie: Ludvigsen, Conradt, Elfrink & similar). The more important it is to you to get an exact spec, the more sources you need to check, & as close to "THE source" as possible.
TC/TeamEvil 09-29-2006 06:06 AM
Just what are you planning to DO to that Pre-A anyway . . . ?
p-nor 09-29-2006 07:17 PM
keep quiet tc, you'll find out soon enough. i do have a plan though.
paul
