Fender project (metalwork inside)
I have almost completed some work that I thought I'd share here. Here was the problem. Old, badly done collision work that had rusted out.
http://forums.pelicanparts.com/uploa...1162778702.jpg I needed to make a piece: http://forums.pelicanparts.com/uploa...1162778766.jpg http://forums.pelicanparts.com/uploa...1162778790.jpg http://forums.pelicanparts.com/uploa...1162778822.jpg I made a "flexible" pattern and a buck, plus the block. http://forums.pelicanparts.com/uploa...1162778849.jpg http://forums.pelicanparts.com/uploa...1162778874.jpg http://forums.pelicanparts.com/uploa...1162778905.jpg |
I found a headlight bucket with some fender attached. Unfortunatley, the fender was a later body, not for the A I was working on. Here's where the real work began:
http://forums.pelicanparts.com/uploa...1162779302.jpg http://forums.pelicanparts.com/uploa...1162779324.jpg http://forums.pelicanparts.com/uploa...1162779363.jpg The metal on the car was really thin. I had to make an additonal piece/patch there on the inside because there was nothing left to weld to. I should have made more fender, but the owner was telling me that I shouldn't spend any more time (money) on this. So, I leaded the old, bad weld that was still solid, POR 15'd the back side and rolled the car. http://forums.pelicanparts.com/uploa...1162779576.jpg http://forums.pelicanparts.com/uploa...1162779604.jpg |
This is as far as I went on this one leaving the general bodywork to the painter.
http://forums.pelicanparts.com/uploa...1162779806.jpg BTW, the weld are gas welds hammered flat after tacking up with the MIG. |
Nice work Milt.
Should I ever crack up my tub racin' on the left coast .... I'll know who to contact :lol: |
Oh, and I slipped in a front battery box while it was here. Not too proud of the fender work, myself, but the owner didn't want to spirng for a fender. That's big money nowadays. This is just a 500 dollar patch job that won't fall out. ;) And, I wanted something to do that required hammer forming a piece.
It was good practice and the owner was the first to say that the car was(is) just a practice car. It's pretty bad elsewhere, like the rear end. This car is a surviver, but barely. It got tagged front anad rear, but managed to make it out in the world for a few more 1000 miles before it just died. He picked it up in AZ for 5K. |
Nice work Milt.
Sherwood |
Those panel holders from eastwood are the best perfect gap for welding nice work
Did you tig weld the panels? That is what I found to be the best way mig is OK and it works just seems like more grinding
"BTW, the weld are gas welds hammered flat after tacking up with the MIG." |
nice work you have done there. A good idea to make the buck and one I will keep in the back of my mind when I do the rear of my 356 ......now to find some chunky wood :-)
| All times are GMT -8. The time now is 05:06 PM. |
