-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   need help with head stud washers (http://forums.pelicanparts.com/porsche-356-technical-forum/372953-need-help-head-stud-washers.html)
earlr85944 10-19-2007 09:05 AM
Hi, its been a while since I disassembled my cyl head for my 1968 912, I installed new rings and now am putting it back together. Being that the parts were in 3 different boxes im not sure: does a washer belong under each head stud nut or just the top row outside of the rocker box?
356RS 10-19-2007 11:03 AM
All of the head studs get a washer under the special nuts. Washer size: Outside dia. 19mm, Inside dia. 10.5mm, and they are 2mm thick.
earlr85944 10-19-2007 01:06 PM
Thanks!
