Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
AC Wiring Help / Advice
AC evaporator blower stopped working on my 82 SC with pure stock AC stsem. No blown fuses but I found one that showed evidence of high current and heat. This turned out to be part of the problem - fuse holder spring lost it's temper due to heat and some evidence of melted wire insulation and previous repairs. One wire is red with white stripe and one red with green stripe. Checked the diagrams and one is the evap blower and the other the front condenser motor. Ammeter shows evap motor drawing 11 amps and condenser motor drawing about 4. I think the fuse is designed to be 20 amp but it has a 25 cast into the back of it. So I need to fix the damaged fuse holder and wire but what to do past that.? Interestingly the wire feeding that fuse (from the top) looks fine.
ANY ADVICE?
KW
Old 06-26-2009, 06:35 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Yeah I know - wrong forum!
Old 06-26-2009, 06:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Acceleration Junkie
Originally Posted by wieringa@mcn.ne View Post
AC evaporator blower stopped working on my 82 SC with pure stock AC stsem. No blown fuses but I found one that showed evidence of high current and heat. . . .
ANY ADVICE?
Unless you can replace the copper fuse contacts or the entire fuse block, I advise you put an in line fuse holder in place of the fuse block. If the previous splice in the secondary wire is not a good one, it is exacerbating the problem which is high current draw through that fuse.
If the fuse serves two devices via two wires into the fuse block, I advise you Y the feed at the fuse block, add two in line fuses of appropriate current capacity.
Chris Toy
356-930 Gone
Old 06-27-2009, 01:45 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
