AV8TOR
356 Engine up-grade
Greetings,
I just purchased a '69 12 motor to graft into my '62 356, that did not have a motor, (I do have the third piece from the original engine with the correct serial number to put on the new motor). The 356 is still has a 6 volt system, and the original gearbox. Will I require a new flywheel? I have not measured the diameter of the flywheel on the new motor, but I am guessing it is a few mm's larger than the bell housing will accommodate. Also when I switch over to the 12volt alternator I am assuming I will need to change out the following list of parts: Windshield wiper motor Voltage regulator All lights Radio (not that important at this point) Are there any tech articles you can direct me to that deal with the 12volt upgrade? Thanks, AV8TOR |
Try looking through the links in this article--most of what you are looking for is here.
http://www.356registry.com/techinfo/repair/6-12volt-index.html |
Yes, you will need a 356 flywheel package. Size and teeth spacing on the 912 won't work for you. Keep the 6 volt starter motor - works good on 12 volts.
Regards, Chuck |
Acceleration Junkie
Add/change the starter motor solenoid to 12V.
Chris Toy 356-930 Gone
