raer axle remove
Need some help...How does the rear axle assemblies come apart from the gearbox?
The axle tubes can be removed from the transmission side cover after removing the axle boot steel side cover. Then the axles along with the ring gear & differential can be removed from the left side of the transmission after the left side cover is removed. You will need a plastic/rubber hammer to drive the complete assembly out from the right axle side.
| All times are GMT -8. The time now is 09:00 AM. |
