wanna buy a stripper pole
356 C caliper detail?
I'm rebuilding the calipers in my '64. I need to know if these were plated to reduce rust and corrosion or are they bare?
TIA
non velox ad propitiare, verisimile non oblivisci 2000 Dakota Sport Pick Up 1966 Corvair Monza Coupe 17.5' CLC Chesapeake |
Yes, they are plated. The original was most likely a clear zinc with a hint of yellow.
Keeper of 911, 912 & 914 databases Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Excellent Thank you
If you have not started all the work you may try your neighbor, CSP he has them complete in proper color, link attached, either way you get to lok at the correct color. Will (owner) has a passion for our cars and has LOTS of parts not available at the regular spots.
Regards Calipers and Kits |
See here a lot of useful information. Very useful
Christina10
Porsche 356 C and 912 pretty much used the same rear caliper. You've got some of each on your car apparently. Not a problem. Regards |
