Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
DrBarrett356
Guest
Posts: n/a
Speedster expert needed in the Las Vegas area
I've developed a very strange rattle from the rear of my Speedster. It is very noticeable when cruising at highway speeds. I'm not sure I should make the drive back to So Cal without having it looked at first. Are there any experts in the Las Vegas area you can recommend?
Old 05-23-2011, 09:03 AM
Speedster Help
Check with the 356 Registry forum. There is also a travel list maintained by the registry. When are you heading back home?
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 05-23-2011, 10:06 AM
DrBarrett356
Guest
Posts: n/a
I was headed back this morning when I noticed the rattle.
Old 05-23-2011, 10:49 AM
Check the shock mounts, not an uncommon issue. Better description of rattle might behelpful. Is it road related or engine related?
Old 05-23-2011, 11:31 AM
Did you get home okay? What was the rattle?
Old 05-27-2011, 07:34 AM
