-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   912 engine in 356? (http://forums.pelicanparts.com/porsche-356-technical-forum/611824-912-engine-356-a.html)
356Axel 06-01-2011 11:57 PM
912 engine in 356?
Hello
What mods are needed to put a 1965 912 engine in a 1958 356?
Axel
id10t 06-02-2011 06:00 AM
Think the older 356s had a 180mm clutch - the C/SC/912 use a 200mm one. Also the 912 is 12 volt generator, the '58 356 is 6v so possibly new bulbs all around and changes to your gauges.
356Axel 06-02-2011 06:18 AM
Hello
Thanks for reply.
Do you know if the larger diameter clutch/flywheel will fit inside the gearbox without mods?
Axel
callard 06-02-2011 07:48 AM
It won't fit and the starter motor and flywheel teeth won't mesh. Suggest you get a 356 flywheel/pplate/TO bearing/clutch and put it on the 912 engine. Also, it's quite a bit easier to put the 356 generator stand and generator on the 912 rather than trying to convert the car to 12 volts.
Chuck
