Banned
will these rims work with drum brakes?
im pretty sure theyre ok but need to hear it from someone in the know, will these alloy space savers work with drum brakes? regards
There is 5 inches between the bolt holes on drum brake cars. Those look smaller. If you measure from a bolt hole on the opposite side it is 8 inches.
63 356 So Called Outlaw 76 930 |
No. Drum brake wheels have a much large bolt pattern.
