-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   Frame dimensions (http://forums.pelicanparts.com/porsche-356-technical-forum/751561-frame-dimensions.html)
WRGREENER 05-22-2013 09:13 PM
Frame dimensions
Can anyone send me the frame dimensions (inner) for my 61 T5 coupe. i need to put it on a frame machine and have not found anyone in my area (santa cruz, ca) that has access to them. i do have them for an "A" that i found in a DER WHITE service manual but i am sure they r not the same for mine.
matt demaria 05-24-2013 02:03 PM
Not sure what "inner" means but frame specs for the t5 are pretty much the same as in the A. If you are putting it on a frame machine, I assume you are concerned about front beam relationships to the rest of the car. Front beam dimensions to the rear reference bolt on torsion bar cover is the same. The battery box IIRC was slightly different but if you have new panels, pull frame so panels
will fit.
You can also buy the B book and see the dimensions
