Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Champagne on Beer Budget
HelmetHead's Avatar
12V coil on a 6V system?
A buddy and I are trying to diagnose a rough running motor in his 356c. The car has a 6volt battery and charging system however I noticed last night that it's got a big sticker on the coil which states 12Volt (looks like a VW bosch blue coil). I read up on this and it seems to be common when converting a 6volt system to 12volts by replacing the points/condenser to 12volt along with the charging system but again, I believe this system is still 6volts
What symptoms would a 12V coil on a 6V system exhibit...it runs fine at low RPM but when we get above 3K with a load it sputters something awful.
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 07-09-2013, 10:21 AM
Could also be a bad condenser.
Old 07-09-2013, 10:24 AM
id10t's Avatar
A 6v coil should still be available... I'd swap it out and see if that fixes it.
Old 07-11-2013, 05:35 AM
304065's Avatar
You lack the requisite ignition energy to fire the plugs. Change to 6v coil.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-25-2013, 06:51 PM
HelmetHead's Avatar
Thank you all for your input. As suggested I put a 6v coil on it a couple of days ago and presto...she runs like a top.
I can see where the 6v input into a 12v coil would fall flat when demand and rpm increases, what I haven't yet determined is the who, when and why a 12v coil on this car.
Einar
Old 07-26-2013, 06:36 AM
