Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Drum Skins for a Wide 5 conversion ?
Can someone explain how everything mounts up when doing a conversion from 4 lug (disc brakes) to "wide 5"/ 5x205mm wheels? Pictures would be even better. I am confused how the aluminum drum skins interact with the stock 4 lug/disc set up.. how do they mount togther etc? In particular I'm referring to the Beck pieces that look like original speedster/spyder equipment where the original 4 lugs do not show. Maybe I'm confused and Beck's do not retain their standard 4 lug set up - but that's the impression you get from their website. Any other vender sell the pieces needed to do this? Thanks in advance!
Old 08-28-2013, 09:11 AM
What 4 lug wheels are you talking about? Stock 356 up to 64 have 5 lugs and most wide 5 wheels will fit with different wheel studs.
Old 08-29-2013, 01:58 PM
Sorry for confusing the matter... I WANT to use the original 5 lug steelies that the 356 and spyders used, the original wide five wheels.
The problem is that my car will have stock 4 lug VW brakes (when I get the car), like the kits cars usually do. That's why I want to convert to wide 5.
Old 08-29-2013, 08:04 PM
Have done that conversion before. The rear is straight bolt on for A brakes (drums and backing plates) onto the vw rear splines. the front I used A brakes again (drums and backing plates) but I designed special collar type shims and employed the vw front wheel bearings (for the four bolt wheels). These were smaller than the porsche wheel bearings and I estimated a loss of 30% in strength. See chuck and maybe he can give you the plans for the machined items. Because of beck's design you have to stick with the 4.5" wide wheels for the front.
Old 08-31-2013, 09:48 AM
