-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   leftover part ID (http://forums.pelicanparts.com/porsche-356-technical-forum/815235-leftover-part-id.html)
lotuseleven 06-08-2014 08:19 PM
leftover part ID
Can someone please tell me where these two Grommets should have been installed on a 356b engine. didn't see any obvious use. each one is around .625 inches OD, .310" ID, .335 thick. Thanks for all help!http://forums.pelicanparts.com/uploa...1402283963.jpg
edit: maybe the grommets from the oil cooler? if so, was replaced, with new grommets.
matt demaria 06-09-2014 04:01 PM
I believe one goes to the tin above the flywheel for the fuel line to pass through.
id10t 06-10-2014 09:11 AM
One more vote for grommets to protect fuel line, clutch cable, etc.
