C rotor minimum thickness specs?
Anybody know what the minimum rotor thicknesses are for a C coupe, front and rear. Not having any luck finding this information.
Also cant search on the 356 registry. Guess that is a members only feature? Thanks!! BK |
From my archive of 356talk emails before they went all forum-y
The shop manual says min thickness of front discs is 9.8mm [.386"]; rears 9.3mm [.366"]. Run-out of fronts .2mm [.008"]; rear .3mm [.012"]. Most brake drums and discs get turned when it isn't necessary. Some roughness is acceptable. |
Thank you! Looks like I need to order some rotors!
I'd also recommend finding a copy of Elfrinks Tech Manual for the 356
Yea, got the Elfrinks but couldnt find the data on the wear limit on C rotors. Did I miss something?
| All times are GMT -8. The time now is 02:56 AM. |
