-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   Help to find where these bits sit? (http://forums.pelicanparts.com/porsche-356-technical-forum/835502-help-find-where-these-bits-sit.html)
slow car 10-24-2014 03:19 AM
Ih , Can anyone show me where these bits fit?
I inherited this 64 SC 100% pulled apart so it is a massive gig-saw puzzle? http://forums.pelicanparts.com/uploa...1414145935.jpg
matt demaria 10-24-2014 06:18 AM
They are air duct plates that fit under the cylinders. The springs hold them in place and are attached to the drain tubes. Obviously there is a left and right side.
slow car 10-24-2014 06:31 AM
Hi Matt, Thanks for that.do you or anyone have a photo?
The cap'n 10-24-2014 02:35 PM
Can't find a photo, but they fit up against the cylinders, above the pushrod tubes, and between the case and the head. Left and right are different to fit over the bolt head on one side and the acorn nut on the other. The wire clips fit over a pushrod tube to hold them tightly in place. The heads and pushrod tubes must be removed in order to install these air guides.
The Cap'n
Miguel Antonett 10-29-2014 06:36 AM
Go to the Stoddard website under engine cooling and you'll find them there...
