-   Porsche 356 Technical Forum (http://forums.pelicanparts.com/porsche-356-technical-forum/)
-   -   Clutch problem….HELP ! (http://forums.pelicanparts.com/porsche-356-technical-forum/956704-clutch-problem-help.html)
scamp62 05-14-2017 07:59 PM
I have a stuck clutch (may be ?) it started with the car’s was seeming to start to fad, I was driving and then it was hard to shift into gear got it home, master cylinder is dry (not leaking ) reservoir was full. So I replaced the slave cylinder, but now the I can not get the car into gear at all ! if the car is running, with the car off it shifts fine. It was suggested (by my brother) but the car in gear and try hitting the starter with the clutch depressed, and it lurched forward. So thoughts, ideas, and or suggestions would be appreciated.
CASair 05-15-2017 09:35 AM
Clutch master/ slave? are you in the right forum?
A clutch in a 356 is just cable operated. Check the cable
