pud pud is offline
Porsche 911 2.4t mfi high idle
Hi , I have a Porsche 2.4t mfi . 1972 , it starts well and idle is at 1000 rpm but when warmed up The idle goes up to 1500 rpm on its own , any idea what might be going on , thank you .
Old 06-20-2018, 09:03 AM
Is your hand throttle all the way down?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-20-2018, 10:51 AM
tobluforu's Avatar
Also, do you have the mfi thermostat heater hose connected?
Old 06-20-2018, 12:47 PM
PRO Motorsports
Tyson Schmidt's Avatar
Check that the vacuum retard on the distributor is working.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-20-2018, 07:27 PM
tobluforu's Avatar
One last thing, if you have not looked at CMA and gone over that at least 50 times, best to start there.
Old 06-21-2018, 03:18 AM
pud pud is offline
High idle
Thanks for all the help , on inspection of the advance and retard, all fine and working , but checking the small rubber hose from the carb to the distributor I found a T piece connector and a small amount of hose coming off it going nowhere, removed the T piece and joined up the pipe , all working well and idle is at 1000 rpm ,
Old 06-21-2018, 09:57 AM
gptom's Avatar
T is to connect left & right vacuum sources then to distributor
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 06-21-2018, 12:33 PM
pud pud is offline
High idle
Ahh , thanks fir the help , I will connect back up to left side mfi stack , it must have just simply come off causing high idle ,
Old 06-22-2018, 12:43 AM
