aluminum control arms interchangability
Are all the years of aluminum control arms interchangeable?
Thanks David |
I assume you are referring to the rear trailing arms? The '74-'77 trailing arms use a different mechanism for attaching the sway bar drop-link to the arms than '78 & later. '74-77 used a ball & socket fitting with a post on the arm, while the later cars bolted the drop link directly into the arm.
Also, the 930 arms are different than the 911.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Thanks Frankc
That is what I was hoping to hear David |
