Cylinder Heads Smog Ports
I am planning on removing all the smog equipment of of my car. Actually the PO removed the air pump and hoses that went to the heads but they didn't seal up the port holes on the heads that the hoses go to. What is the best thing to use to seal up this hole?
1975 Widebody 911 3.2 Euro |
There is a OEM part, I think from Mercedes, that screws right in. I know there is a post sometime ago with the part number. Maybe someone will chime in.
Super Moderator
Yep... There is a specific part for this... I think Wayne discussed it...
Aha... Here it is with the part num. Air pump injection blanking plugs question.
John Adams 1980 ROW 911SC |
i just used some 1/4-20 allen head bolts on mine, they threaded in just fine and it has been 1 year since I put them in with no leaks and none fell out. I t just happened to be what I had in my assortment of hardware.
