930/10 versus 930/04 Ignition Timing Specs
Before I was a 930/10 owner, I had the original US Cali delivered '78 3.0 930/04 in my car.
IIRC, igintion timing spec on that motor is 5 Deg BTDC at idle and 25-26 Deg Advanced @ 6k RPM (timed it a couple times but about 3 years ago) Now that I'll be bolting the '83 930/10 motor in my car (ideally) this weekend...is the ignition timing spec the same as above? Thanks SauCe |
spec fr these is max not above 25 BTD checked at 4000rpm, earlier SC ran up to 31BTDC the RoW don't mention an idle spec, US does 5BTDC all w/ vacuum disconnected |
Really, don’t check the advance w vac connected?
It's why I asked :) Thank you |
| All times are GMT -8. The time now is 08:06 AM. |
